| Oracle® Communications Cloud Native Diameter Routing Agent (CNDRA) Installation Guide Release 1.0 F16991-02 |
![]() Previous |
![]() Next |
This section includes information about the configurable parameters required during deployment.
Configuration used by clientPod chart
| Attribute Name | DataType | Range | Default Value | Mandatory(M)/Optional(O)/Conditional(C) | User can change? | Description |
| ClientOverseer:replicaCount | <integer> | Min-1, Max-2 | 2 | M | N | Option to configure the overseer replicacount number. It determines the number of pods replicas created for Deployment. |
| Cidr | <IPv4 address> | valid IPv4 address | N/A | M | Y | Option to configure the cidr address.
The Classless Inter-Domain Routing allows flexible allocation of IP addresses. kubernetes assigns the CIDR block per node, to utilize the ip address allocated to each POD, within each Node. |
| ClientNetwork: isDualNetwork | <boolean> | true/false | false | M | N | Option to enable/disable dual network. It is a flag to specify the deployment is single network based or dual network. When set true, it enables client network to be deployed on dual ip address based network, when set false, it enables client network to be deployed on single ip address based network. |
| ImageName | <string> | N/A | cndraclient | M | Y | option to tag image name with user specific name |
| Version | <string> | N/A | 1.0.0 | M | Y | option to tag image with user defined version |
overseerSvc chart:
OverseersvcDeployment
and
OverseerService object
| name | <string> | maximum of three characters include null character | nd | M | Y | Option to configure the overseersvc deployment name. |
| container_name | <string> | N/A | overseer | M | Y | Option to configure the overseer container name |
| ImageName | <string> | N/A | cndra | M | Y | Option to tag image name with user specific tag:
| Version | <string> | N/A | 1.0.0 | M | Y | Option to tag image with user defined version |
| memory | <integer> | in gigabytes | 6Gi | M | Y | Option to configure to a valid memory |
| cpu | <integer> | Min-4, Max-8 | 4 | M | Y | Option to configure available CPU |
| values | <string> | N/A | overseer | M | Y | Option to configure a valid name. |
| svcname | <string> | N/A | overseer-svc | M | Y | Option to configure a valid service name. |
| annotations: metallb.universe.tf/address-pool | <string> | N/A | oam | M | Y | Option to configure a valid metalLB. |
draSvc chart:
DrasvcDeployment and
DraSvcObject
| name | <string> | maximum of two characters | mp | M | Y | Option to configure the drasvc deployment name. |
| ImageName | <string> | valid image version | cndra | M | Y | Option to give user specific image name:
| Version | <string> | N/A | 1.0.0 | M | Y | Option to tag image with user defined version. |
| dualNetwork | <Boolean> | true/false | false | M | N | Option to configure for valid dual network. It is a flag to specify CNDRA deployment on single ip address based network or dual ip address based network. It has dependency on CNE environment when using multiple network plugin. |
| memory | <integer> | in gigabytes | 8Gi | M | Y | Option to configure a valid available memory. |
| cpu | <integer> | Min-4, Max-8 | 4 | M | Y | Option to configure to available memory. |
| values | <string> | N/A | dra | M | Y | Option to configure a valid name. |
| nodeselector: node | <string> | N/A | N/A | O | Y | Option to configure a valid node selector name. |
| svcname | <string> | N/A | dra-svc | M | Y | configure to a valid dra service name. |
| sig1-sig5 | <integer> | 3868-3872 |
3868, 3869, 3870, 3871, 3872 |
M | Y | configure to a valid port range. |
| annotations: metallb.universe.tf/address-pool | <string> | N/A | signalling | M | Y | configure to a valid metalLB. |
Configuration used by clientPod and draSvc Charts: global
| global: | ||||||
| draReplicaCount | <integer> | Min-0, Max-32 | 4 | M | Y | Option to configure a valid mp replicacount |
| Repo | <string> | N/A | occndra-registry:5000 | M | Y | Option to configure docker registry from where images will be pulled |
