| Oracle® Communications Cloud Native Diameter Routing Agent (CNDRA) Installation Guide Release 1.0 F16991-02 |
![]() Previous |
This section includes a sample Yaml file required for CNDRA deployment.
custom_values.yaml is
provided below:
clientPod:
ClientOverseer:
replicaCount: 2 # Default value is 2
Cidr: 10.244.0.0 # depends on the Cidr used in cluster
ClientNetwork:
isDualNetwork: false
ImageName: cndraclient # Default image name
Version: 1.0.0 # Default version of the image
overseerSvc:
container_name: overseer
ImageName: cndra # Default image name of cndra
Version: 1.0.0 # Default version of the cndra image
memory: 6Gi
cpu: 4
values: overseer
svcname: overseer
# This is the default annotation which will be set for the MetalLB.
# If user wants to add their own annotations then they have to update this attribute in their
# customized_values.yaml file.
annotations:
metallb.universe.tf/address-pool: oam
draSvc:
dualNetwork: false
memory: 8Gi
cpu: 4
values: dra
# If you want to assign dra pods to specific worker nodes of the cluster then provide a node_selector name
# in node
# CMD : kubectl label node worker_node_hostname node:node_selector name
# Example: kubectl label node worker_node_hostname node=<value>, where <value> is used as label value
# to fine eligible Node to schedule the Pod.
# nodeSelector:
# node: [default = empty, no label value applied e.g. node: <value>]
# else all the dra pods can be schdueled on any worker node
nodeSelector:
node:
annotations:
metallb.universe.tf/address-pool: signaling
svcname: dra
ports:
sig1: 3868 # Default value is 3868
sig2: 3869 # Default value is 3869
sig3: 3870 # Default value is 3870
sig4: 3871 # Default value is 3871
sig5: 3872 # Default value is 3872
global:
draReplicaCount: 4 # Default value is 4
Repo: occndra-registry:5000
