| Oracle® Communications Cloud Native Diameter Routing Agent (CNDRA) Installation Guide Release 1.0 F16991-02 |
![]() Previous |
![]() Next |
The following procedure describes the steps to download the CNDRA Images and Helm files from OSDC.
Table 2-3 CNDRA Installation Preparation
| Step | Procedure | Description |
1
Download the OCCNDRA package file |
Customers are required to download the CNDRA package file from Oracle Software Delivery Cloud (OSDC). Package is named as follows: <OCCNDRA>-pkg-<release-number>.tgz For
example:
2
Untar the OCCNDRA Package File |
Untar the CNDRA package: tar -xzvf <<OCCNDRA>-pkg-<release-number>>.tgz This command results into
The directory consists of following:
3
Check the checksums | Verify the checksums of tarballs mentioned in
Readme.txt.
Refer to the
4
Load the tarball to system |
Execute the following command to push the Docker images to docker registry: docker load --input occndra-images-1.0.0.tar |
5
Check if all the images are loaded |
Execute the following command to check: docker images Refer table CNDRA Image Files in section CNDRA Installation Sequence for the list of images. |
6
Push docker images to docker registry |
Execute the following commands to push the docker images to docker registry:
For
example:
For
example:
Where,
7
Untar Helm Files |
Untar the helm files: tar -xzvf occndra-1.0.0.tgz |
8
Download the Cloud Native Diameter Routing Agent (CNDRA) Custom Template ZIP file |
Template ZIP file:
