| Oracle® Communications Cloud Native Diameter Routing Agent (CNDRA) Installation Guide Release 1.0 F16991-02 |
![]() Previous |
![]() Next |
This section includes information about CNDRA deployment in CNE environment.
Table 2-4 CNDRA Installation
| Step # | Procedure | Description |
1
Prepare
custom_values.yaml file
Prepare a
To configure the parameters, see section CNDRA Configurable Parameters. or,The
Download the Cloud Native Diameter Routing Agent (CNDRA) Custom
Template ZIP file and Unzip to get
2
Deploy CNDRA using HELM repository | Execute the following command:
Where: helm-repo: repository name where the helm images, charts are stored. custom_values: helm configuration file which needs to be updated based on the doctor registry deployment_name and namespace_name: depends on customer configuration |
3
Deploy CNDRA using HELM tar | Execute the following command:
4
Check repo status | Execute
helm
ls to check the deployment status.
5
Check svc status | Check if all the services are deployed and
running:
6
Check pod status | Check if all the pods are up and running:
Note: The
Status and Ready columns for all the Pods must show
7
Check deployment status | Execute the following command to check the
status of the deployment:
Table 2-5 Parameters and Definitions
| Parameters | Definitions |
<helm chart>
It is the name of the chart that is of the
form
<helm
repo>/occndra
<OCCNDRA version>
It is the software version (helm chart version) of the CNDRA. This is optional, if omitted, the default version is the latest version available in helm repository. |
<release>
It is a name provided by the user to identify the helm deployment |
<namespace_name>
It is a name provided by the user to identify the kubernetes namespace of the CNDRA. All the CNDRA micro services are deployed in this kubernetes namespace. |
<helm-repo>
It is the name of repository where the helm charts are stored. |
<Chart Path>
The location of the helm chart |
