| Oracle® Communications Service Communication Proxy (SCP) Cloud Native Installation Guide Release 1.0 F12352-01 |
![]() Previous |
![]() Next |
Following are the prerequisites to install and configure SCP:
SCP Software
Following software are required as must to deploy SCP:
Table 2-1 SCP Software
| Software | Version |
| Kubenetes | v1.12.5 |
| HELM | v2.11.0 |
Other services may need to be deployed according to the requirement of services. Following are software details:
Table 2-2 SCP Services
| Software | Chart | Notes |
| elasticsearch | elasticsearch-1.21.1 | Needed for Logging |
| elastic-curator | elasticsearch-curator-1.2.1 | Needed for Logging |
| elastic-exporter | elasticsearch-exporter-1.1.2 | Needed for Logging |
| logs | fluentd-elasticsearch-2.0.7 | Needed for Logging |
| kibana | kibana-1.5.2 | Needed for Logging |
| grafana | grafana-2.2.0 | Needed for Metrics |
| prometheus | prometheus-8.8.0 | Needed for Metrics |
| prometheus-node-exporter | prometheus-node-exporter-1.3.0 | Needed for Metrics |
| metallb | metallb-0.8.4 | Needed for External IP |
| metrics-server | metrics-server-2.4.0 | Needed for Metric Server |
| tracer | jaeger-0.8.3 | Needed for Tracing |
In case above services are needed and software are not installed in CNE. Install all the required software before proceeding for SCP Installation.Network access
The Kubernetes cluster hosts must have network access to:
All the kubectl and helm related commands used in this guide need to be executed on some machine depending on the infrastructure/deployment. It may be some client machine.Client machine requirements
kubectl commands. The
environment should have privileges to create namespace in the Kubernetes
cluster.
helm
install command deploys the software in the Kubernetes cluster.
