Oracle® Communications Service Communication Proxy (SCP) Cloud Native Installation Guide Release 1.0 F12352-01 |
![]() Previous |
![]() Next |
Table 2-3 provides the sequence in which SCP must be installed.
Table 2-3 Installation Sequence
Sl.No | Phase | Description |
1 | Installation Preparation | Download the required files and load the files to the system, which is having access to Kubectl and helm commands. |
2 | Configure custom_values.yaml file. |
This includes configuring the following based on the deployment:
Note: Other configurations might be changed based on the deployment. |
3 | SCP deployment | SCP can be deployed in either of the
following ways:
4 | Verify SCP deployment | Check if the services and pods are up and running. |
SCP Images
Following are the SCP images:
Table 2-4 SCP Images
Microservices | Image |
SCP-Worker | scp-worker |
SCPC-Pilot | scpc-pilot |
SCPC-Soothsayer | soothsayer-configuration |
soothsayer-init | |
soothsayer-notification | |
soothsayer-subscription | |
soothsayer-audit | |
soothsayer-reconfiguration |
