| Oracle® Communications Security Edge Proxy Protection (SEPP) Cloud Native Installation Guide Release 1.1 F17667-01 |
![]() Previous |
![]() Next |
Installation Sequence provides the sequence in which SEPP must be installed.
Table 2-1 Installation Sequence
| Sl.No | Phase | Description |
| 1 | Installation Preparation | Download the required files and load the files to the system. |
| 3 | SEPP deployment | |
| 4 | Verify SEPP deployment | Check if the pods are up and running. |
