Refer to the “Pre-requisites” prior to proceeding with the next section.
This is the second step to be executed. It is assumed that model building routine mentioned in the previous section is already processed.
As part of this process, data will be refreshed as of the current date. The customer attrition model that has been built in the previous step will be loaded and executed. As part of this routine the customer life time value and segmentation models will get built and executed runtime.
User(s)
It is suggested that only the FLEXCUBE user with admin rights should have access to the model execution screens
Launch ‘Model Execution and Control’ screen from the menu
Machine Learning Retail -> Model Administration -> Model Execution and Control
Select "Model Execute" radio button
Data Fields |
Remarks |
Period Start Date |
Will get defaulted to 12 months prior to Period End date. User can modify. |
Period End Date |
Will get defaulted
to the latest date across branches. |
Attrition Date |
Will get defaulted to Period End date. Not allowed to modify |
Silent Period to consider for attrition identification |
Will get defaulted to 180 days. Not allowed to modify |
Suggestions:
Process ‘Model Execute’ routine
Click ‘Process’ button to trigger model execution.
Periodic Model Execution
Note
