show registration
The show registration command displays cumulative statistics on all current registrations.
ORACLE# show registration
15:35:43-177
SIP Registrations -- Period -- ----- Lifetime ------
Active High Total Total PerMax High
User Entries 0 0 0 0 0 0
Local Contacts 0 0 0 0 0 0
Via Entries 0 0 0 0 0 0
AURI Entries 0 0 0 0 0 0
Free Map Ports 0 0 0 0 0 0
Used Map Ports 0 0 0 0 0 0
Forwards - - 0 0 0 0
Refreshes - - 0 0 0 0
Rejects - - 0 0 0 0
Timeouts - - 0 0 0 0
Fwd Postponed - - 0 0 0 0
Fwd Rejected - - 0 0 0 0
Refr Extension 0 0 0 0 0 0
Refresh Extended - - 0 0 0 0
ContactsPerAor Reject - - 0 0 0 0
Surrogate Regs 0 0 0 0 0 0
Surrogate Sent - - 0 0 0 0
Surrogate Reject - - 0 0 0 0
Surrogate Timeout - - 0 0 0 0
HNT Entries 0 0 0 0 0 0
Non-HNT Entries 0 0 0 0 0 0
Database Regs 0 0 0 0 0 0
DDNS Entries 0 0 0 0 0 0
CX Entries 0 0 0 0 0 0
LocalDB Entries 0 0 0 0 0 0
Unreg Users 0 0 0 0 0 0
You can extend upon the show registration command by adding the sipd by-user <username> detail arguments. The resulting output reflects user registration information including downloaded IFCs. For example:
ORACLE# show registration sipd by-user +19999092907 d
Registration Cache (Detailed View) MON JUN 25 2012 13:47:46
User: sip:+19999092907@mobile.com
Registered at: 2012-06-25-13:43:50 Surrogate User: false
Contact Information:
Contact:
Valid: true
Challenged: false
Last Registered at: 2012-06-25-13:47:30
Expire: 48
Local expire: 13
Registrar IP: 0.0.0.0
Transport: UDP
Secure: false
Local IP: 155.212.214.175:5060
User Agent Info:
Contact: sip:+19999092907@50.76.51.62:5762;transport=udp;acme_nat=+19999092907+50.76.51.62@10.1.10.20:5762
Realm: access
IP: 50.76.51.62:5762
SD Info:
Contact: sip:+19999092907-rb8tulsbv3u72@108.108.108.108:5060
Realm: core
Call-ID: H_yvkgTAAA@10.1.10.20
Associated URI(s):
URI: sip:+19999092907@mobile.com
Filter Criteria:
Priority: 0
Filter: ((case == 'Originating Registered') and (method == INVITE) and ('Accept-Contact'=='+g.app2app')) or
((case == 'Originating Registered') and (method == INVITE) and ('Contact'=='+g.app2app')) or
((case == 'Originating Registered') and (method == INVITE) and ('P-Message-Auth'=='.*')) or
((case == 'Originating Registered') and (method == INVITE) and ('P-Application-ID'=='.*'))
Application Server: sip:pza.mobile.com:5280
Reg Event Subscriptions Received by Registrar:
Number of Subscriptions : 2
Subscriber: sip:appserv@192.168.13.1:5060; state=active; exp=59978
Subscriber: sip:pcscf@192.168.13.1:5060; state=active; exp=978
