show home-subscriber-server
The show home-subscriber-server command displays cumulative statistics on all currently configured HSS servers.
show home-subscriber-server [stats <hss-name>| group group-name ]
This command allows you to gather a set of information commonly requested by the Oracle TAC when troubleshooting customers.
The show home-subscriber-server command with no arguments displays the status of each HSS as well as the number of transactions and connections per HSS. For example:
ORACLE# show home-subscriber-server
Name Local-Address Server-Address Status
hss1 192.168.207.21:45463 192.168.200.232:3872 Up
18:53:25-105
HSS Status -- Period -- -------- Lifetime --------
Active High Total Total PerMax High
Client Trans 0 1 4 12152 8 1
Server Trans 0 0 0 7 2 1
Connections 1 1 0 53 2 1
Note that the Connections statistic indicates the number of connections after successful CER/CEA handshake.
The table below documents the states the
| Field | Description |
| Active | This status is related to HSS failover and load balancing configurations. The diameter connection is up and being used. |
| Standby | This status is related to HSS failover and load balancing configurations. The diameter connection is up, but is not being used. |
| Pending | The Oracle Communications Core Session Manager has sent a CER and is waiting for a CEA response. |
| Inactive | The Oracle Communications Core Session Manager has sent a CER but has not received a CEA response. |
| Down | The Oracle Communications Core Session Manager is not attempting to establish a connection with the HSS. |
Oracle Communications Core Session Manager reports on each HSS.
The show home-subscriber-server command with the stats argument displays the number of transactions and connections per HSS as well as the number of messages exchanged with all HSS servers per message type. For example:
ORACLE# show home-subscriber-server stats
veloster2# show home-subscriber-server stats
18:55:03-103
Client Trans 1 1 5 12157 8 1
---- Lifetime ----
Recent Total PerMax
UAR 0 3 1
SUBSEQ_REG (2002) 0 3 1
SAR 0 6 3
SUCCESS (2001) 0 6 3
MAR 0 4 2
SUCCESS (2001) 0 4 2
LIR 0 1 1
SUCCESS (2001) 0 1 1
RTR 0 1 1
PPR 0 1 1
CER 0 55 3
SUCCESS (2001) 0 53 2
DWR 5 12088 5
SUCCESS (2001) 4 12041 5
ERR_TIMEOUT 0 46 1
DWR Recv 0 5 2
SUCCESS (2001) 0 5 2
TCP Failures 0 267 6
By entering the name of a specific HSS as an argument, the ACLI displays all HSS data for that server only. For example:
ACMESYSTEM# show home-subscriber-server stats hss1
The show home-subscriber-server command with the group argument displays the number of transactions and connections per the HSS group you specify in the command. For example:
ORACLE# show home-subscriber-server group hss-group1
display grp hss-group1
Client Trans 0 0 0 0 0 0
Server Trans 0 0 0 0 0 0
Sockets 0 0 0 0 0 0
Connections 0 0 0 0 0 0
---- Lifetime ----
Recent Total PerMax
UAR 0 0 0
SAR 0 0 0
MAR 0 0 0
LIR 0 0 0
RTR 0 0 0
PPR 0 0 0
Sent Requests 0 0 0
Sent Req Accepted 0 0 0
Sent Req Rejected 0 0 0
Sent Req Expired 0 0 0
Sent Req Error 0 0 0
Recv Requests 0 0 0
Recv Req Accepted 0 0 0
Recv Req Rejected 0 0 0
HSS Errors 0 0 0
