set-component-type
Use the set-component-type command to define the system's operational mode as either SLRM or CSM..
From superuser mode, use the following ACLI command sequence to access the
set-component-type configuration element.
- core-session-manager—Defines the device as an I-CSCF and S-CSCF.
- core-load-balancer—Defines the device as an I-CSCF and SLRM.
The device responds by displaying user requirements for changing component type. If the user attempts to set the component type to the current component type, the system provides a message indicating this and takes no further action.ORACLE# set-component-type core-load-balancer WARNING: Changing component type is service impacting. ******************************************************** Ensure that you follow these steps if you choose to change the component type: 1. Issue the delete-config command. 2. Reboot. ******************************************************** Continue with the change [y/n]?:
Type
y to make the change.
The system displays a message indicating the component type.
- Be sure to delete-config and reboot to complete the procedure.
