lb-interface
Use the following procedure to perform required lb-interface configuration.
From superuser mode, use the following ACLI command sequence to access the
lb-interface configuration element.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# lb-interface ORACLE(lb-interface)#
- name—Use the name parameter to specify the name for this interface.
- state—Enables or disables this interface for the Sc interface.
- address—Specifies the IP address of the SLRM from which this Oracle Communications Core Session Manager sends Sc interface traffic.
- port—Specifies the port on the SLRM interface from which the Oracle Communications Core Session Manager sends Sc interface traffic.
- realm—Specifies the local realm to which this Sc interface applies.
