lb-core-config
Use the following procedure to perform required lb-core-config configuration.
From superuser mode, use the following ACLI command sequence to access the
lb-core-config configuration element.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# lb-core-config ORACLE(lb-core-config)#
- core-name—Use the core-name parameter to specify the name of this lb-core-config. This name must match the name of an lb-config on the Oracle Communications Core Session Manager.
- state—Enables or disables this lb-core-config instance.
- domains—List of domains associated with this core. This list must match that of the corresponding registrar at the Oracle Communications Core Session Manager.
- forwarding-realm—Specifies the realm of the SLRM interface from which it sends Sc interface traffic.
hss-config—Specifies the name of the hss-config that matches the applicable HSS. The SRLM sends UARs and LIRs associated with this core to this HSS.
Note - The configuration options described in the Primary and Secondary ENUM Configuration section within the Diameter Oracle CSM chapter applies to the lb-core-config element. See that section for instructions on configuring those options here.
