Oracle CSM Configuration
This section describes the configuration necessary to allow an Oracle Communications Core Session Manager to join an SLRM load balanced cluster. Configuration is simplified to allow for an easy and seamless migration.
Configuration required at the Oracle Communications Core Session Manager includes:
- service-cluster-id— A parameter within the system-config element that specifies the load balanced cluster to which this Oracle Communications Core Session Manager belongs.
- lb-cfg—A multi-instance element identifying the Sc listening interface on the SLRM(s).
- sip-registrar—This configuration element has two applicable parameters.
- ims-core—Parameter that specifies the matching SLRM core name to which this registrar applies.
- lb-cfg—List of lb-cfg elements that this registrar uses to register its cores.
The following subsections explain these configurations.
