service-cluster-id
Use the following procedure to perform service-cluster-id configuration within the system-config element on the Oracle Communications Core Session Manager.
  1. From superuser mode, use the following ACLI command sequence to access
the system-config configuration element.
    ORACLE# configure terminal
    ORACLE(configure)# system-config
    ORACLE(system-config)#
  2. Select the system-config element. The system-config element is a single-instance element.
  3. Use the service-cluster-id parameter to specify the load balanced cluster to which this Oracle Communications Core Session Manager belongs. The default value is null, which ensures that this Oracle Communications Core Session Manager can participate as a load balanced device with SLRM even though it has not been explicitly configured.
    ORACLE(system-config)# service-cluster-id new_york
