lb-cfg
Use the following procedure to perform required lb-cfg configuration.
From superuser mode, use the following ACLI command sequence to access the
lb-configconfiguration element.ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# lb-config ORACLE(lb-config)#
- name—A name for this lb-cfg element.
- state—Enables or disables this configuration. When enabled, the Oracle Communications Core Session Manager starts Sc interface signaling to this target SLRM.
- address—Specifies the IP address of the SLRM to which this Oracle Communications Core Session Manager sends Sc interface traffic.
- port—Specifies the port on the SLRM interface to which the Oracle Communications Core Session Manager sends Sc interface traffic.
- realm—Specifies the local realm to which this Sc interface applies.
