Message Based Testing
When the Oracle Communications Core Session Manager first receives a message applicable for manipulation, it checks if the message type as request, response, or all as configured in the msg type parameter. The Oracle Communications Core Session Manager continues to look at the message command code. Matching values are defined by configuring the msg cmd code parameter with a numeric value. You can enter a single value, multiple comma-separated values, or you can leave this parameter blank to indicate all message codes.
