Naming Diameter Manipulations
The Oracle Communications Core Session Manager restricts the way you can name a diameter-manipulation rule. Specifically, observe the rules below when naming manipulation elements:
- Character limit - diameter manipulation rule names cannot be longer than 24 characters.
- Numeric characters - diameter manipulation rule names must not start with a numeric character.
- Special characters - Special characters are not supported within diameter manipulation rule names, with the exception of the underscore and hyphen characters.
- Capital letter characters - The Oracle Communications Core Session Manager includes reserved keywords that are named using all-capital letters. To avoid conflicts between keywords and diameter manipulation rules, do not configure diameter manipulation rule names using ll capital letters.
Note that, although diameter-manip-rule and avp-header-rule names have the same character-type restrictions, they do not have a character limit.
