SVA Message Format
The following table contains the top level AVPs present in an SLRM-generated SVA message.
| AVP | Number | Reference | Type | Grouped |
| { Vendor-Specific-Application-ID } | 260 | Base | Grouped | Vendor-Id
Auth-Application-ID |
| [ Result-Code ] | 268 | Base | Unsigned32 | |
| { Origin-Host } | 264 | Base | DiameterIdentity | |
| { Origin-Realm } | 296 | Base | DiameterIdentity | |
| { Service-Assoc-Id } | 4010 | Oracle | String | |
| { Req-Type } | 4000 | Oracle | Enumerated | |
| { Sc-Proto-Ver } | 4005 | Oracle | Unsigned32 | |
| { Soft-Ver } | 4014 | Oracle | Integer | |
| { Srv-Assoc-Exp } | 4012 | Oracle | Unsigned32 | |
Experimental-Result-Code |
