SVR Message Format
The following table contains the top level AVPs present in a Oracle Communications Core Session Manager-generated SVR message.
| AVP | Number | Reference | Type | Grouped |
| { Vendor-Specific-Application-ID } | 260 | Base | Grouped | Vendor-Id
Auth-Application-ID |
| { Origin-Host } | 264 | Base | DiameterIdentity | |
| { Origin-Realm } | 296 | Base | DiameterIdentity | |
| { Srv-Assoc-Id } | 4010 | Oracle | String | |
| { Req-Type } | 4000 | Oracle | Enumerated | |
| { Sc-Proto-Ver } | 4005 | Oracle | Unsigned32 | |
| { Soft-Version } | 4014 | Oracle | String | |
| { Srv-Assoc-Exp } | 4012 | Oracle | Integer | |
| { Destination-Realm-AVP } | 283 | Base | DiameterIdentity | |
| { Cluster_Id } | 4001 | Oracle | Integer | |
| { Pct-Used-Cpu } | 4002 | Oracle | Unsigned32 | |
| { Pct-Used-Mem } | 4003 | Oracle | Unsigned32 | |
| { Eps-Srv-Count} | 4004 | Oracle | Unsigned32 | |
| [ Max-Eps-Supp ] | 4006 | Oracle | Unsigned32 |
