diam-stats-detail
This group consists of statistics pertaining to diameter messaging between the OCCSM and HSS servers. The data is based on the show home-subscriber-server stats ACLI command.
| Position | Statistic | Type | Range | Description |
| 1 | TimeStamp | Integer | 0 - 2147483647 | The window of time that the HDR collector used to collect the data in seconds. |
| 2 | UAR-LifeTime Total | Counter | 0 - 2147483647 | The total number of User-Authorization-Requests (UAR) sent to all HSS servers. |
| 3 | UAR Error | String | The most recent error text or the string "NO ERROR". | |
| 4 | UAR Error-LifeTime Total | Counter | 0 - 2147483647 | The total number of errors associated with UAR messages sent to all HSS servers. |
| 5 | SAR-LifeTime Total | Counter | 0 - 2147483647 | The total number of Server-Assignment-Requests (SAR) sent to all HSS servers. |
| 6 | SAR Error | String | The most recent error text or the string "NO ERROR". | |
| 7 | SAR Error-LifeTime Total | Counter | 0 - 2147483647 | The total number of errors associated with SAR messages sent to all HSS servers. |
| 8 | MAR-LifeTime Total | Counter | 0 - 2147483647 | The total number of Multimedia-Auth-Request (MAR) sent to all HSS servers. |
| 9 | MAR Error | String | The most recent error text or the string "NO ERROR". | |
| 10 | MAR Error-LifeTime Total | Counter | 0 - 2147483647 | The total number of errors associated with MAR messages sent to all HSS servers. |
| 11 | LIR-LifeTime Total | Counter | 0 - 2147483647 | The total number of Location-info-Request (LIR) sent to all HSS servers. |
| 12 | LIR Error | String | The most recent error text or the string "NO ERROR". | |
| 13 | LIR Error-LifeTime Total | Counter | 0 - 2147483647 | The total number of errors associated with LIR messages sent to all HSS servers. |
| 14 | RTR-LifeTime Total | Counter | 0 - 2147483647 | The total number of Registration-Termination-Request (RTR) sent to all HSS servers. |
| 15 | RTR Error | String | The most recent error text or the string "NO ERROR". | |
| 16 | RTR Error-LifeTime Total | Counter | 0 - 2147483647 | The total number of errors associated with RTR messages sent to all HSS servers. |
| 17 | PPR-LifeTime Total | Counter | 0 - 2147483647 | The total number of Push-Profile-Requests (PPR) sent to all HSS servers. |
| 18 | PPR Error | String | The most recent error text or the string "NO ERROR". | |
| 19 | PPR Error-LifeTime Total | Counter | 0 - 2147483647 | The total number of errors associated with PPR messages sent to all HSS servers. |
| 20 | CER-LifeTime Total | Counter | 0 - 2147483647 | The total number of Capability-Exchange-Requests (CER) sent to all HSS servers. |
| 21 | CER Error | String | The most recent error text or the string "NO ERROR". | |
| 22 | CER Error-LifeTime Total | Counter | 0 - 2147483647 | The total number of errors associated with CER messages sent to all HSS servers. |
| 23 | DWR-LifeTime Total | Counter | 0 - 2147483647 | The total number of Device-Watchdog-Requests (DWR) sent to all HSS servers. |
| 24 | DWR Error | String | The most recent error text or the string "NO ERROR". | |
| 25 | DWR Error-LifeTime Total | Counter | 0 - 2147483647 | The total number of errors associated with DWR messages sent to all HSS servers. |
| 26 | DWR Recv-LifeTime Total | Counter | 0 - 2147483647 | The total number of Device-Watchdog-Requests (DWR) received by the OCCSM from all HSS servers. |
| 28 | DWR Resp Sent | Counter | 0 - 2147483647 | The total number of responses to Device-Watchdog-Requests (DWR) sent by the OCCSM to all HSS servers. |
| 29 | DWR Resp Sent-LifeTime Total | Counter | 0 - 2147483647 | The total number of responses to Device-Watchdog-Requests (DWR) sent by the OCCSM to all HSS servers. |
| 30 | TCP Failures-LifeTime Total | Counter | 0 - 2147483647 | The total number of TCP failures that have occurred between the OCCSM and the HSS server. |
| 31 | Message Recv -LifeTime Total | Counter | 0 - 2147483647 | The total numbers of diameter messages received by the OCCSM from all HSS servers. |
| 32 | Message Trans-LifeTime Total | Counter |
0 - 2147483647 |
The total numbers of diameter messages sent by the OCCSM to all HSS servers. |
