diam-stats-summary
This group presents system-wide diameter message statistics on HSS connectivity. The data is based on the show home-subscriber-server ACLI command.
| Position | Statistic | Type | Range | Description |
| 1 | TimeStamp | Integer | 0 - 2147483647 | The window of time that the HDR collector used to collect the data in seconds. |
| 2 | Client Trans-Period Active | Counter | 0 - 2147483647 | Total number of client-initiated message transactions (sent to) all HSS servers in the current window of time. |
| 3 | Client Trans-LifeTime Total | Counter | 0 - 2147483647 | Total number of client-initiated message transactions (sent to) all HSS servers. |
| 4 | Server Trans-Period Active | Counter | 0 - 2147483647 | Total number of server-initiated message transactions (received from) all HSS servers in the current window of time. |
| 5 | Server Trans-LifeTime Total | Counter | 0 - 2147483647 | Total number of server-initiated message transactions (received from) all HSS servers. |
| 6 | Connection Period Active | Counter | 0 - 2147483647 | Total number of message transactions associated with all client-server connections in the current window of time. |
| 7 | Connection LifeTime Total | Counter | 0 - 2147483647 | Total number of message transactions associated with all client-server connections. |
