HDR Groups on HSS Data
The Oracle Communications Core Session Manager (OCCSM) and Oracle Communications Unified Session Manager (OCUSM) provides the same Historical Data Reporting (HDR) function as provided with the Oracle Communications Session Border Controller (OCSBC). HDR is a mechanism that provides for ongoing reporting of system information. HDR descriptions and instruction are provided in the HDR Resource Guide.
The OCCSM includes HDR groups that are not documented in the HDR Resource Guide. Those groups include:
- diam-stats-summary—diameter statistics summary
- diam-stats-detail—diameter statistics detail
- diam-stats-per-hss—diameter statistics per HSS
These HDR groups align with the output of the show home-subscriber-server ACLI command.
You configure and work with these groups using the same approach and procedures as other HDR groups. The data provided by these groups is presented here so you can identify it and parse the HDR files correctly.
