Enabling Anonymization of Information Sent to OCOM
When
you want to hide certain sensitive information in a SIP
INVITE message that
the Oracle Communications Operations Monitor (OCOM) can display, you can
configure the
Oracle Communications Core
Session Manager (OCCSM) to anonymize the
SUBJECT header in
the message and in the CPIM body, as well as the MIME content of the CPIM body
with the
anonymize-invite
option.
You can enable the same functionality for the SIP MESSAGE method using the anonymize-message option. You can enable both options on the same comm-monitor, if desired using the options' plus-sign (+) syntax.
The default setting for these anonymize options is disabled. Use the options parameter in the comm-monitor configuration to enable them.
