Registration Event Profile Configuration
To configure a registration event profile:
From superuser mode, use the following command sequence to access
regevent-notification-profile command.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# regevent-notification-profile ORACLE(registration-event-profile)#
To define the profile, simply name it and specify a timeout in
seconds.
ORACLE(registration-event-profile)# name reg-event-profile1 ORACLE(registration-event-profile)# min-subscription-duration 2500 ORACLE(registration-event-profile)# done ORACLE(registration-event-profile)# exit
Navigate to the registrar for which you want registration event
package support.
ORACLE(session-router)# sip-registrar ORACLE(sip-registrar)# regevent-notification-profile reg-event-profile1 ORACLE(sip-registrar)# done ORACLE(sip-registrar)# exit
