Optional NOTIFY Refresh Frequency
To specify optional NOTIFY refresh frequency:
From superuser mode, use the following command sequence to access
registration-event-profile command within session router.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# regevent-notification-profile ORACLE(registration-event-profile)#
To enable NOTIFY, set the send-notify-for-reg-refresh option to
the time, in seconds,
ORACLE(registration-event-profile)# options notify-refresh-interval=1800 ORACLE(registration-event-profile)# done ORACLE(registration-event-profile)# exit
Prepend the option with the + sign if you have multiple options configured that you want to retain.
ORACLE(registration-event-profile)# options +notify-refresh-interval=1800
Running the command without the + character causes the system to remove any previously configured options.
