Configuring ODI Preservation Perform this sequence to enable ODI preservation on the OCCSM on a global basis. Access the sip-config configuration element. ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# sip-config ORACLE(sip-config)# Select the sip-config object to edit. ORACLE(sip-config)# select ORACLE(sip-config)# preserve-odi—Set this parameter to enabled. The default value is disabled. ORACLE(sip-config)# preserve-odi enable Save your work.
