Setting Up an IMS-AKA Profile
An IMS-AKA profile establishes the client and server ports to be protected, and it defines lists of encryption and authentication algorithms the profile supports. You can configure multiple IMS-AKA profiles, which are uniquely identified by their names.
You apply an IMS-AKA profile to a SIP port configuration using the name.
To configure an IMS-AKA profile:
