Setting Up an IPSec Profile for IMS-AKA Use
Using the global IPSec configuration, you establish the parameters governing system-wide IPSec functions and behavior. This configuration also contains parameters required for IMS-AKA support. The IPSec global configuration is a single instance element, meaning there is one for the whole system.
To configure the global IPSec parameters that apply to IMS-AKA:
