USM Base Configuration Elements for ENUM
This appendix provides configuration samples of the elements that are required for minimal Oracle USM operation.
| The SIP Config must be enabled |
sip-config
state enabled
| You must have a default gateway in your system-config |
system-config
default-gateway 10.0.0.1
| You must have an access physical interface |
phy-interface
name s0p0
operation-type Media
port 0
slot 0
| You must have a core physical interface |
phy-interface
name s0p1
port 1
slot 0
| You must have an access network interfaces |
network-interface
name s0p0
sub-port-id 0
ip-address 192.170.1.100
netmask 255.255.255.0
gateway 192.170.1.1
| You must have a core network interfaces |
network-interface
name s0p1
sub-port-id 0
ip-address 192.170.2.100
gateway 192.170.2.1
| You must have an access realm |
realm-config
identifier access1
addr-prefix 0.0.0.0
network-interfaces s0p0:0
| You must have a core realm |
realm-config
identifier core1
addr-prefix 0.0.0.0
network-interfaces s0p1:0
| You must have an access SIP interface |
sip-interface
state enabled
realm-id access1
sip-port
port 5060
transport-protocol UDP
allow-anonymous registered
trust-mode none
registration-caching enabled
ims-access enabled
| You must have a core SIP interface |
sip-interface
state enabled
realm-id core1
sip-port
| You must have an ENUM Configuration for e.164 translation |
enum-config
name My_e164_cfg
realm-id core1
enum-servers 192.170.2.201
| You must have an ENUM Configuration for accessing ENUM server(s) as subscriber server(s) |
enum-config
name My_ENUM_servers
realm-id core1
enum-servers 192.170.2.203
cacheInactivityTimer 0
max-response-size 65535
| You must have an Authentication Profile |
sip-authentication-profile
name My_Auth_Profile
methods REGISTER
anonymous-methods *
digest-realm My_Digest_Realm.com
credential-retrieval-method enum-text
credential-retrieval-config My_ENUM_servers
| You must have a Sip-Registrar |
sip-registrar
name My_Registrar_Name
domains my_customer1.com
subscriber-database-method DDNS
subscriber-database-config My_ENUM_servers
authentication-profile My_Auth_Profile
home-server-route sip:192.170.2.201:5060
routing-precedence REGISTRAR
egress-realm-id core1
options e164-primary-config=enum:My_e164_Cfg
