USM Base Configuration Elements for LST
This appendix provides configuration samples of the elements that are required for minimal Oracle USM operation.
| The SIP Config must be enabled |
sip-config
state enabled
| You must have a default gateway in your system-config |
system-config
default-gateway 10.0.0.1
| You must have an access physical interface |
phy-interface
name s0p0
operation-type Media
port 0
slot 0
| You must have an access network interfaces |
network-interface
name s0p0
sub-port-id 0
ip-address 192.170.1.100
netmask 255.255.255.0
gateway 192.170.1.1
| You must have an access realm |
realm-config
identifier access1
addr-prefix 0.0.0.0
network-interfaces s0p0:0
| You must have an access SIP interface |
sip-interface
state enabled
realm-id access1
sip-port
port 5060
transport-protocol UDP
allow-anonymous registered
trust-mode none
registration-caching enabled
ims-access enabled
| You must have a Local Subscriber Table |
local-subscriber-table
name My_LST
filename /code/lst/My_LST.xml
secret *******
| You must have an Authentication Profile |
sip-authentication-profile
name My_Auth_Profile
methods REGISTER
anonymous-methods *
digest-realm My_Digest_Realm.com
credential-retrieval-method local
credential-retrieval-config My_LST
| You must have a Sip-Registrar |
sip-registrar
name My_Registrar_Name
domains my_customer1.com
subscriber-database-method LOCAL
subscriber-database-config My_LST.xml
authentication-profile My_Auth_Profile
routing-precedence REGISTRAR
