If you are adding support for this feature to a pre-existing realm, then you must select (using the ACLI select command) the external policy server that you want to edit.
provision-signaling-flow—Set this to enabled for the
Oracle Communications Unified
Session Manager to send AAR messages to a PCRF on endpoint registrations.
