Troubleshooting
Upon receipt of AAA response from PCRF for the AAR sent, the Oracle Communications Unified Session Manager logs the status of the AAA received. Successful AAAs are noted by session-ID in EBMD logs. The log will look like:
Provision of SIP Signaling Flow (<session-ID>) via Diameter Rx on realm <realm-id> successful.
Failed AAA response are noted at NOTICE level EBMD logs citing the failure response to AAR request with the session-ID sent. An a MINOR non-health-affecting alarm is also raised with the following text:
Provision of SIP Signaling Flow (<session-ID>) via Diameter Rx on realm <realm-id> failed.
