ACLI Instructions
To globally enable force-unregistration at the sip-config level:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session router path.
ORACLE(configure)# session-router
Type
sip-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-config ORACLE(sip-config)#
Type
select to continue.
ORACLE(sip-config)# select ORACLE(sip-config)#
options—Set the options parameter by typing
options, a Space,
force-unregistration with a plus sign in front of it, and then press Enter.
ORACLE(sip-config)# options +force-unregistration
If you type the option without the plus sign, you will overwrite any previously configured options. In order to append the new options to the realm configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
- Type done and exit to complete configuration of this sip-config configuration element.
