SIP Interface Configuration
To configure the SIP Interface configuration element portion of the ENUM Database update feature:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session router path.
ORACLE(configure)# session-router
Type
sip-interface and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
Type
select and choose the number of the pre-configured sip interface you want to configure.
ORACLE(sip-interface)# select <realm-id>: 1: private 192.168.101.17:5060 2: public 172.16.101.17:5060 selection: 1
unregister-on-connection-loss—Set this parameter to
enabled for the
Oracle Communications Unified
Session Manager to update the ENUM server when an endpoint is deemed failed.
Parameters for determining endpoint reachability:
- tcp-keepalive—You may set this parameter to enabled to enforce the network-parameters configuration element located in the system-config path. See the Oracle SBC ACLI Configuration guide, System TCP Keepalive Settings section for more information.
register-keep-alive—Set this parameter to
always for the
Session Manager to return the
keep parameter, with optional value (as configured in the next two steps) in the Via: header to an endpoint including an empty keep value in its initial REGISTER message.
You may set none, one, of both the following for a keep value returned to the initiating endpoint. Read the RFC 5635 Failure section for how the actual value is determined:
- inactive con timeout—Set this parameter value to the value in seconds inserted in the returned keep parameter for RFC 5635 support
tcp nat interval—Set this parameter value to the value in seconds inserted in the returned keep parameter for RFC 5635 support
Type done and exit to complete configuration of this sip-interface configuration element.
