PreviousNextJavaScript must be enabled to correctly display this content
Configuring the Plug-in Option
For the SPL to work, you must configure it to recognize your http-server configuration. You do this by setting the sts-server option at the sip-registrar. This option is required for plug-in functionality.
To configure the sts-server option:
In Superuser mode, type configure terminal and press Enter.
ORACLE# configure terminal
Type session-router and press Enter.
ORACLE(configure)# session-router
Access the target sip-registrar by typing sip-registrar, selecting your registrar and pressing Enter.
