Synchronizing SPL Files Across HA Pairs
When running in an HA configuration, both the active and the standby systems must have the same version of the SPL plugins installed. To facilitate configuring the standby system, you can executing the synchronize spl ACLI command (without any arguments) to copy all files in the /code/spl directory from the active system to the same directory on the standby, overwriting any existing files with the same name.
By adding the specific filename as an argument to the synchronize spl command, the individual, specified scripts are copied between systems. For example:
ORACLE#synchronize spl SMXOauth2.spl
The synchronize spl command can only be executed from the active system in a HA pair. There is no means to synchronize SPL files automatically during a save and activate of the Oracle Communications Unified Session Manager.
To sychronize all SPL Plug-ins to the configuration:
