Executing SPL Files
There are two ways to execute SPL files:
- Perform a save-config and activate-config after exiting the configuration menu.
Execute the
reset spl command—all configured SPL files are
refreshed by with the
reset spl command. You can also refresh a
specific file by typing
reset spl <spl-file>.
Oracle suggests that scripts are only refreshed during planned maintenance windows.If an SPL file exists in the /code/spl directory, but is not configured in the spl-files parameter, it will be ignored when the ACLI User Interface is booting.
