Reloading the LST
After copying a new LST file to the Oracle Communications Unified Session Manager (and its standby peer), you can reload this newer file from the ACLI using the refresh lst command. For example:
ORACLE# refresh lst <local-subscriber-table name>
Using the refresh lst command selects the LST by name to refresh. Alternatively, saving and activating the configuration will reload the configuration as well and should be used when configuration parameters have also changed.
In an HA pair of Oracle Communications Unified Session Managers, you must independently execute the refresh lst command on both the active and standby systems.
