LST Redundancy for HA Systems
LSTs must be synchronized between redundant nodes to ensure that the standby node contains identical LST files. You can either SFTP the same LST file to both the active and standby node, or you can use the synchronize command. The synchronize command is always executed from the active system. It copies the specified file from the active to the standby node placing the copy in the same file location on the standby node. Use the synchronize lst command as follows:
ACMESYSTEM# synchronize lst file.xml
The synchronize command does not reload the LST files.
