Configure Users
A user is a person who logs into the system to perform application-related operations. Before this user can access any operations, they must be added to a user group. Each user group has a defined set of privileges. The operations that a user can do depends on the privileges of the user group to which the user belongs.
The following users are created by default when OCSDM is installed:
- admin—Inherits the privileges from the administrators group.
- LIadmin—Inherits the privileges from the LIadministrators group.
Upon installation of OCSDM, if R226 compliance is enabled, the Lawful Intercept and SIPREC features and their attributes are hidden from view and are not configurable.Users (other than the default users) are created, added, and given the privileges of the user groups to which they are assigned so that they can access OCSDM.
Reactivate a User
A user can be denied access to OCSDM if the user is disabled, expired, the user password expired, or the user logs in more times (due to failed log in attempts) than is allowed by the maximum login fail attempts value.
You can reactivate a user by editing the user profile to reset the status of the user to enable, then reset the expiration in days for the account and password parameters. You can also delete the expired user and recreate the user.
The following table lists the possible causes for user deactivation and how to reactivate the user.
| Cause | Action |
| User expired | Reset the calendar to a new date. |
| Password expired | Reset the password calendar to a new date. |
| Password deactivated | Reactivate the user account by:
| User disabled | Reset the user to enabled. |
Reset a User Password
Pre-requisites: You must have the proper permissions to reset passwords.
- Expand the Security Manager slider and select User management, Users.
- In the Users pane, click a user from the table and click Reset Password.
- In the Reset password dialog box, enter a new password for the user in the field provided.
- The dialog box indicates if you entered the new password successfully. Click OK.
Change a User Password
If you have administrative operations permission, you can change the password of a user.
Change User Password Rules
Use this task to change the password rules that specify the length of the password, how many times it can be reused, and whether specific characters, such as a numeric value, can be used.
Notify When to Change the User Password
You can configure when the user is notified to change their password before it expires.
When the user logs into OCSDM, the system checks user credentials and the password expiry time for the user. If the password is due to expire, a warning is displayed that prompts the user to change their password.
- Expand the Security Manager slider and select User management, Password notification.
- In the Password expiration notification panel, enter a value in the Days prior to password expiration field.
- Click Apply.
