Apply or Change User Group Privileges
Upon installation of OCSDM, if R226 compliance is enabled, the Lawful Intercept and SIPREC features and their attributes are hidden from view and are not configurable.User group privileges that are assigned to either the administrators or LIAdministrators user groups inherit most of the same access privileges. However, users assigned to the LIAdministrators user group have full configuration privileges to manage the Configure LI element (Lawful Intercept) in the Device configuration subfolder within the Configuration folder in the Configuration tab. Users assigned to administrators, provisioners and monitors default user groups do not have privileges to configure the Configure LI element.
If Lawful Intercept (LI) is enabled on the device, LI configuration values become encrypted on both the devices and OCSDM.All user group privileges that are available through OCSDM are described in the following sections. You may not see some of these user group privileges in the Configuration, Device maintenance, Administrative operations, Fault management, Device groups, and Applications tabs in OCSDM until you install your product plugin.
Apply User Group Privileges for Device Maintenance
- Expand the Security Manager slider and select User management, Groups.
- In the User Groups pane, select the group you want to modify from the User Groups table and click Edit.
- Select the Device maintenance tab to modify user group privileges and click on the folder slider to expand the item operations list.
- Choose the item row in the operation category table that you want to modify and click the Privileges column to activate the drop-down list.
In the
Privileges drop-down
list, choose the following options:
- Full—The user group is allowed to reboot a device.
- None—The user group is not allowed to reboot a device.
- Click Apply.
Apply User Group Privileges for Fault Management Operations
An element manager system (EMS) must be licensed to apply user-group privileges for fault management operations that apply to the events and alarms that appear on the Fault Manager slider.
Apply User Group Privileges for Device Groups
Use this task to apply user-group privileges for device groups that appear on the Device Manager slider.
Apply User Group Privileges for Route Manager
Use this task to apply user-group privileges for Oracle Communications Session Delivery Manager configurations.
Depending on your user privileges in Oracle Communications Session Delivery Manager, you can enable privileges to configure route set groups and templates, perform backups or restore route sets, and perform route set operations on devices.
