Configure User Groups
A user group is a logical collection of users grouped together to access common information or perform similar tasks in OCSDM. The default LIAdministrators, administrators, provisioners, and monitor user groups are provided in OCSDM for you, or you can add new user groups so that you have the flexibility to define specific privileges for them based on the unique needs of your users. You can also map a local default user group or a local user group that you add in OCSDM to an external domain user group provided by RADIUS or LDAP authentication so that the external group can inherit the authorization privileges of the local user group.
Upon installation of OCSDM, if R226 compliance is enabled, the Lawful Intercept and SIPREC features and their attributes are hidden from view and are not configurable.
