Select the Installation Type for Session Delivery Manager
Choose from the following installation types for
Oracle Communications Session
Delivery Manager based on the setup options that are available for each
installation type.
- Typical Installation—Specify the most common setup properties to get a basic Oracle Communications Session Delivery Manager installation running on the server, which includes configuring passwords for the default user accounts, the global identifier, web server security, and the SNMP Trap Relay port for Fault Manager.
- Custom Installation—Configure the mail server, manage clusters, Route Manager, configure the Report Manager database instance, and Transport Layer Security (TLS) certificates.
- Easy Installation— Specify the minimum number of properties to get started. The majority of the settings are defaulted.
- Headless Installation—Specify the options supported in the Easy Installation through a file.
The following table describes each setup option and in which installation type this setup option is available:
| Setup Option | Typical Installation | Custom Installation | Easy Installation | Headless Installation |
| Admin Password | Yes | Yes | Yes | Yes |
| R226 Compliance | Yes | Yes | Yes | Yes |
| LI Admin Password | Yes | Yes | Yes | Yes |
| Global Identifier | Yes | Yes | Yes | Yes |
| HTTPS Apache User | Yes | Yes | No | No |
| HTTPS Apache Group | Yes | Yes | No | No |
| HTTPS Apache Port Number | Yes | Yes | No | No |
| HTTPS Server Name | Yes | Yes | Yes | Yes |
| Certificate Alias Name | Yes | Yes | No | No |
| Trust Store Password | Yes | Yes | Yes | Yes |
| HTTPS Private Key File [Path] | Yes | Yes | No | No |
| HTTPS Certificate File [Path] | Yes | Yes | No | No |
| HTTPS Intermediate Certificate File [Path] | Yes | Yes | No | No |
| Web Server File Size Limit [GB] | Yes | Yes | No | No |
| Enable TLS versions 1.1 and 1.2 | Yes | Yes | No | No |
| Trap Relay Port Number | Yes | Yes | No | No |
| Fault Configuration Sudo Password | Yes | Yes | Yes | Yes |
| Mail Server DNS Name | No | Yes | No | No |
| Mail Server Secure Protocol | No | Yes | No | No |
| Mail Server Port | No | Yes | No | No |
| Mail Server From | No | Yes | No | No |
| Mail Server User ID | No | Yes | No | No |
| Mail Server Login Required | No | Yes | No | No |
| Extra Mail Server Properties | No | Yes | No | No |
| Cluster Member IP Address | No | Yes | Yes | Yes |
| SFTP Username | No | Yes | No | No |
| SFTP Password | No | Yes | Yes | Yes |
| Route Set Number of Backups | No | Yes | No | No |
| SAML Responder Username | No | Yes | No | No |
| SAML Responder Password | No | Yes | No | No |
| SAML Responder Connection Timeout | No | Yes | No | No |
| SAML Certificate Alias Name | No | Yes | No | No |
| SAML Certificate File [Path] | No | Yes | No | No |
| SBI TLS Entity Certificate Common Name | No | Yes | No | No |
| SBI TLS Entity Certificate Org Unit | No | Yes | No | No |
| SBI TLS Entity Certificate Org | No | Yes | No | No |
| SBI TLS Entity Certificate City or Locality | No | Yes | No | No |
| SBI TLS Entity Certificate State or Province | No | Yes | No | No |
| SBI TLS Entity Certificate County Code | No | Yes | No | No |
| SBI TLS Entity Certificate Key Size | No | Yes | No | No |
| SBI TLS Entity Certificate Validity (Days) | No | Yes | No | No |
| Generate Certificate Signing Request (Path) | No | Yes | No | No |
| Export Entity Certificate (Path) | No | Yes | No | No |
| Import Signed Entity Certificate (Path) | No | Yes | No | No |
| SBI TLS Trusted Certificate Alias Name | No | Yes | No | No |
| SBI TLS Trusted Certificate Import File (Path) | No | Yes | No | No |
| Oracle DB OCSDMDW OCSREMDW Password | No | Yes | No | No |
| Oracle DB OCSDMDW Oracle Home (Path) | No | Yes | No | No |
The following table describes the parameters that can be configured in the Easy Installation and Headless Installation.
| Setup Option | Default Value | Configurable |
| Admin Password | N/A | Yes |
| R226 Compliance | N/A | Yes |
| LI Admin Password | N/A | Yes |
| Global Identifier | (Product Mode) | Yes |
| HTTPS Server Name | N/A | Yes |
| Trust Store Password | N/A | Yes |
| Fault Configuration Sudo Password | N/A | Yes |
| Cluster Member IP Address | N/A | Yes |
| SFTP Password | N/A | Yes |
| HTTPS Apache User | nncentral | No |
| HTTPS Apache Group | nncentral | No |
| HTTPS Apache Port Number | 8443 | No |
| Certificate Alias Name | nncentral | No |
| HTTPS Private Key File [Path] | N/A | No |
| HTTPS Certificate File [Path] | N/A | No |
| HTTPS Intermediate Certificate File [Path] | N/A | No |
| Web Server File Size Limit [GB] | 2 GB | No |
| Enable TLS versions 1.1 and 1.2 | Yes | No |
| Trap Relay Port Number | 162 | No |
