R226 Compliance
Upon initial installation, the Oracle Communications Session Delivery Manager can be configured to enable or disable R226 compliance. When R226 compliance is set to enabled on OCSDM, the Lawful Intercept and SIPREC features and their attributes are hidden from view and are not configurable.
disabled, the Lawful
Intercept and SIPREC features and their attributes can be seen and configured
by users with the appropriate permissions.
Once R226 compliance has been enabled, it cannot be revoked without a complete reinstallation of the OCSDM. However, if R226 compliance is disabled, you can enable it at any time.
