Custom Installation
The custom installation options are for more advanced users. The first four steps of the custom installation are identical to the steps of the typical installation. The following custom options are displayed:
  • Mail server configuration
  • Cluster management—See the Configure the New Cluster section in the Typical Installation chapter and the Session Delivery Manager Server Cluster Maintenance chapter in the Oracle Communications Session Delivery Manager Administration Guide for more information.
  • Route Manager configuration
  • Transport layer security (TLS) configuration
  • Oracle Database configuration
Once you have accomplished the applicable tasks, and the required configuration of the NNCentral account in the Pre-Installation Tasks chapter, you are ready to begin this installation. We recommend that you record all the setup parameters that you configure in this chapter. You will need to use them again the next time you upgrade OCSDM and run the Custom installation.
