Start the Custom Installation
  1. Login to the server as the root user.
  2. Navigate to the Oracle Communications Session Delivery Manager installation bin directory.
    For example:
    cd /<sdm-install-directory>/AcmePacket/NNC<version>/bin
  3. Run the setup application with the setup.sh script.
    ./setup.sh
    A warning message appears if you have less than the recommended minimum physical memory. Proceeding without the recommended minimum physical memory may result in performance degradation.
    WARNING:
    This process may take several minutes to complete. Interrupting the setup.sh process risks corrupting the system.
  4. Select option 2, Custom. Press Enter to continue.
    [ ] 1 - Typical        : Runs through most common set up options.  (Recommended) [Default]
    [X] 2 - Custom         : Allows manual customization.              (Advanced users)
    [ ] 3 - Easy-Install   : Prompts user for minimal setup option values.
    [ ] 4 - Quit           : Finish and quit setup.
  5. Enter Yes to continue.
    The following main custom installation options appear:
    [X]  1 - R226 compliance and Default user account passwords   [Default]
    [ ]  2 - Global identifier configuration
    [ ]  3 - Web Server configuration
    [ ]  4 - Fault Management configuration
    [ ]  5 - Mail Server configuration
    [ ]  6 - Cluster management
    [ ]  7 - Route Manager Central configuration
    [ ]  8 - SAML Single sign on configuration
    [ ]  9 - SBI TLS configuration
    [ ]  10 - Oracle DB OCSDMDW configuration. Please drop this DB, if it already exists.
    [ ]  11 - Quit setup
    Option 8, SAML Single sign on configuration for importing self-signed certificates into the Route Manager certificates file (cacerts), is not supported in this release.
