Headless Installation
The Headless Installation of Oracle Communications Session Delivery Manager is a fast, simplified installation process that runs without the setup application. Use the tasks in this chapter to specify the user_setup.properties file and run a setup script that points to this file. When you run the setup script, OCSDM is installed on your server.
Complete the following tasks before you begin this installation:
  1. Complete all applicable tasks in the Pre-Installation Tasks chapter.
  2. Configure the NNCentral account. Refer to the Configure the NNCentral Account section for more information.
  3. You must unzip the tar file to create the OCSDM installation directory, which contains the installation program used to run the installation. Refer to the Create a Session Delivery Manager Installation Directory section for more information.
  4. Ensure that this installation is the type of installation that you want to do. Refer to the Select Installation Type for Session Delivery Manager section for more information.
