Add a Work Order In a Bulk Device Deployment
You can add a new work order to an existing bulk device deployment.
- Expand the Device Manager slider, select Bulk device deployment, and click the Bulk Device Deployment tab.
- Click Add.
In the
Settings pane,
complete the following fields:
Name The name of the work order; this must be an alphanumeric value and cannot contain spaces. Scheduled Indicate whether the work order is scheduled or not. Start date and time Select the date and time when the work order is to be executed; This field is enabled only when the Scheduled checkbox is checked. -
In the
Offline Config Spreadsheet pane, complete the
following fields:
Device Cluster The name of the device cluster for this work order. Offline Configuration The name of the associated offline configuration for this work order. Offline Config Spreadsheet The name of the offline config spreadsheet for this work order. - Click Apply.
