Manage Bulk Device Deployment Work Orders
The Bulk Device Deployment page allows you to manage bulk device deployment work orders.
The Bulk Device Deployment page is comprised of 2 tables, Work orders and Device Details.
The following table describes the Work order table's fields:
| Name | The name of the work order. |
| Platform | The platform associated with the offline config. |
| Offline Config | The offline config for which the work order is created. |
| File name | The name of the offline config bind variable spreadsheet. |
| Device Cluster | The name of the Device Cluster associated to the offline config. |
| Status | The status of the work order.
The following are valid values:
| Start time | The time the work order started or is scheduled to start. |
| End time | The time at which the work order completed, including both successful and unsuccessful completions. |
The following table describes the Device Details table's fields:
| Device Name | The name of the device as specified in the spreadsheet. |
| IP Address | The IP address of the device as specified in the spreadsheet. |
| Status | The status of the device after a work order has been executed. This value is either Success or Failure. |
The following buttons are available to manage bulk device deployment
work orders on the
Bulk Device Deployment page:
| Refresh | Refreshes the work order table. |
| Search | Search through work orders using pre-defined criteria. |
| Show All | Show all existing work orders associated with this bulk device deployment. |
| Logs | Opens a new window displaying the logs for the selected work order (if it has been executed). |
| Add | Creates a work order. |
| Start | Starts an already created work order; this button is only enabled when you have selected a row. |
| Edit | Allows you to edit certain details of a selected, existing work order. |
| View | Allows you to view the details of a work order. |
| Abort | Allows you to abort a work order that has started or is scheduled to start; this button is only enabled when you have selected a row. |
| Delete | Deletes a work order; you cannot delete a work order currently in progress. |
